Auto Heat Issue
Old Mar 4, 2009 | 09:26 PM
isuannie's Avatar
Auto Heat Issue
A month or so ago I had my battery replaced and a sub-woofer installed (which required the removal of my dash) within a week. Since then my auto temperature has not worked. When put in auto it will warm up and when it's ready, will blow full blast and never regulate itself to match the desired temperature. Not to mention it will only blow super hot air unless it's put on 60 in manual. Did something get disconnected? Something get fried? Or does something have to be reset when the power is disconnected? Any help is appreciated!
Old Mar 4, 2009 | 09:47 PM
miltoda's Avatar
The temp probe inside the car didn't get connected when you had the audio install done.
Old Mar 4, 2009 | 09:49 PM
isuannie's Avatar
Thanks so much!
Old Mar 13, 2009 | 10:49 AM
lfs2010's Avatar
I have a similar issue, my car just sets itself on auto a/c and i cant shut it off. The buttons are disabled and the screen from the radio goes blank. Is this caused by the same problem?
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
