Clutch Pedal Clicking Noise??
Old Apr 7, 2009 | 09:14 PM
Sals G35 Coupe's Avatar
I have an 05' G Coupe and my clutch pedal is making a clicking noise. It is mostly noticeable when releasing clutch slowly while down shifting. Has anyone experienced this before, or experiencing it now? I had the pedal replaced a year ago under warranty and it went away, but it started up again. The tech that replaced it before is now saying it sounds normal to him. So something was wrong a year ago and now its normal???? Find the logic in that. I am no longer under warranty and my dealer tells me that warranty replaced parts are only covered under the life of the vehicle warranty. If I had paid for it to be replaced, then it would have a 1 year warranty. Sounds like Bull to me. Anyways, any opinions or suggestions?
Thanks
Old Nov 18, 2015 | 02:38 AM
manniegee22's Avatar
clicking problem
i had the same problem and couldnt stand the clicking. bare in mind i have an aftermarket clutch assembly so i dont know how similar it is but my clicking was caused by a loose bolt on the assembly. all i did was tighten the bolt and the clicking went away
Old Nov 18, 2015 | 09:15 PM
saywat?'s Avatar
grease may help
Old Nov 19, 2015 | 04:38 AM
Tyke420's Avatar
Yeah, if I were you OP I'd just lube it up.... Works great most of the time....
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
jbmw002
Sep 10, 2015 12:54 AM
TheBay
Sep 3, 2015 03:27 PM
