what engine upgrades can i do that.....
Old May 8, 2009 | 08:39 AM
johnsonp's Avatar
wont void too much warranty? i've added a cold air intake and i want to get a HKS exhaust system. what else????
Old May 8, 2009 | 08:52 AM
Beebo's Avatar
you can get a plenum spacer and put the engine cover back on so the dealer cant see it
Old May 8, 2009 | 09:02 AM
johnsonp's Avatar
thanks, yeah a few people told me to get one of those is it easy to install?
Old May 8, 2009 | 09:54 AM
vhtran's Avatar
^ should be easy, just unbolt the screws, slap it in and bolt it back.
Old May 8, 2009 | 10:02 AM
gary c's Avatar
Installing a MotorDyne 5/16" spacer ISO takes about an hour if you're organized and have a tork wrench. Their instructions are very complete as is the spacer that comes with everything you need to install....best bang for your buck! Good choice of exhaust too, HKS is an amazing system....quality, sound and performance.... Also John, if you'll try using of SEARCH all the answers to your questions can be found there including install instructions for everything. FYI
Gary
Old May 8, 2009 | 10:49 AM
ttrank's Avatar
Grocery getter
Plenum spacer for sure.
Old May 8, 2009 | 11:51 AM
eurodre's Avatar
remember that in order to void your warranty the dealership has to link the problem to the mods you have, but everything that has been suggested is a good step
Old May 8, 2009 | 02:53 PM
jutn35's Avatar
G35 Coupe
i put one of these on and no problems 0-80 in 1.21 jiggawatts
Old May 8, 2009 | 10:53 PM
Gtrpnoyracer's Avatar
one thing i understand about warranty is that the warranty cannot be voided unless the dealership can prove that the aftermarket part thats installed is the cause of failure for the car....remember that...
jsimonk
Dec 22, 2023 03:49 PM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
ZoominG35
Dec 6, 2015 03:11 PM
Blakelyg35
Aug 15, 2015 12:12 PM
TWASkyliner
Aug 1, 2015 11:43 AM
