TPMS question installing?
Old May 25, 2009 | 03:23 PM
stangswide3's Avatar
i have an 04 g35 coupe, i have the 17"'s on it now with the tpms. I just bought the upgraded 19 oem forged rays. Would i be able to switch the sensors into the 19's? How easy if so to do this. thanks
Old May 25, 2009 | 07:45 PM
Vrod-Mike's Avatar
You should be able to just swap them out. Unscrew the nuts and pull them out. Very simple.
Old May 25, 2009 | 08:43 PM
yea i eas just checing making sure the sensors weren't different from 17's to 19's, and i never did them, do you just unscrew where the valve stem is?
Old May 25, 2009 | 09:14 PM
Vrod-Mike's Avatar
Yes it's simple as can be.
Old May 26, 2009 | 04:35 PM
one last question its it worth it to do the switch i mean the tires have to come off as well dont they?
Old Jul 7, 2009 | 04:49 PM
lionhb26's Avatar
bump... same question
Old Jul 7, 2009 | 05:15 PM
i took it to a tire place and they did the swap for me fairly cheap....without the them installed in the tires, your light on your dash will come on once in a while, i personally think its worth it if you can fit them. this way theres no annoying light that comes on while your driving.
Old Jul 7, 2009 | 05:27 PM
TVang's Avatar
A member on here has a thread on how to swap. SN: VITTY
Old Sep 7, 2010 | 02:52 PM
kdizzel's Avatar
I have a set of Piaa Rozza wheel. Does anyone know if the OEM TPMS can be installed on this wheel? I know that there is an adapter for it from Iforged, but just want to double check if the wheel will have enough clearance for installation. Thanks!
Old Sep 7, 2010 | 10:16 PM
RogerG35's Avatar
TPMS can be installed for most if not all wheels. For my varizana t1s, they just stick out (But if i hit potholes on the correct spot then im screwed, because my tires are scretch so the tpms isnt too far in). But if anyone plans to buy the tpms, discount tire sells it for half the price of the dealerships and installs for free
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
TheKnite
Aug 14, 2015 07:59 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
