AC turns off at high speed
Old Aug 9, 2009 | 09:16 AM
mloid025's Avatar
I have noticed that when i get on the highway or on a country road going about 60 MPH my AC will start blowing warm air. I live in Houston and its been 100+ everyday for a while now and its getting annoying. It blows ice cold at idle and when i start accelerating, im not sure if it happens when I hit 6th gear or if its a MPH thing. I will repost when i have some time to test it out...any ideas?
Old Aug 9, 2009 | 12:11 PM
miltoda's Avatar
I bet it is low on freon. As the RPMs climb, you'll increase the pressure difference between the low side and high side. Most A/C systems have a sensor to detect low refrigerant levels and cut the compressor to prevent it from burning up. This used to happen in my old corolla so that's the experience I have with this type of thing.
Old Aug 11, 2009 | 10:09 AM
mloid025's Avatar
havnt had a chance to check freon but i did find out it cuts out right at about 50 MPH just about every time..
Old Aug 11, 2009 | 11:15 AM
Q45tech's Avatar
Hopefully you are not confusing the WOTand high acceleration cut off to avoid the compressor from turning more than 4,000 rpm.
Old Aug 11, 2009 | 11:31 AM
miltoda's Avatar
Q45tech, u sure the compressor clutch will disengage over 4,000 rpms? To the OP, how about reving the motor in park with the AC on instead of putting it in gear. Same response?
Edit, nevermind about the compressor clutch disengaging. A quick google search showed that this is very common for newer card to cut the compressor at certain RPM threshold / throttle input.
Old Aug 12, 2009 | 03:37 PM
mloid025's Avatar
hmm.. did not know that, kinda silly but smart i guess. I will check when I leave work
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
