A/C keeps running & stereo display doesn't appear
I have a '03 G35 Coupe and I realize that the first year had electrical issues and in the past I've had to reset ECU by disconnecting negative battery terminal. This usually solves the problem for a few months and then the problem crops up again. This time though the removal of the negative battery cable and pumping of brakes or removal of negative battery cable for more than 8 hrs. isn't doing the trick. I'm suspecting something else might be amiss. Also I've tried detailed ECU reset procedure with no success (i.e. light doesn't appear). Any ideas or suggestions besides bringing it in and getting ripped off.
baker2795
Sep 2, 2015 06:00 PM
