2004 G35X problems with dashboard lights, alarm and window
Old Jan 16, 2010 | 01:40 AM
bv2685's Avatar
Hello. I am new here and any help would be appreciated. I purchased this car 3 weeks ago. Four days ago, I drove off a curb and heard a loud bang. It was either the rim banging onto the cement because I had low tire pressure in that tire, or something under my car hit the curb. That is the only thing that happened that may have caused the following problems. Today as I was driving, I noticed every time i flick the driver side window switch up to close it, the window goes all the way up then drops halfway down and stops. It will still close but I have to hold the switch until it is fully closed. Along with that problem, when I turn my head lights on or to automatic, all the lights on my dash including the radio and temperature lights will turn off. My alarm is also starting to go off for no reason whether my doors are locked or unlocked. There might be more problems but I haven't noticed them yet.
Old Jan 17, 2010 | 09:16 AM
GrocryGettr's Avatar
Your window problem is caused by the limit switch in the window motor. It is a common problem and you will need to replace it.
The other electical problems will be hard to diagnose. Make sure all of the fuses and relays are good and if so, take it to a qualified tech.
Old Jan 21, 2010 | 05:57 PM
G'dUp954's Avatar
some times my window doesnt go up... so i used a long flat head screw driver and hit the window motor... and it started moving again.. but sometimes it wont go up again... it bothers me.. i got an 03 coupe
Old Feb 6, 2010 | 10:39 AM
Pratt's Avatar
the lights going off happened on my 328i bmw it was the fuses
Old Oct 21, 2012 | 02:28 PM
RAYNYC's Avatar
i have the same issue with 2 of my windows, the 2 i had replaced when someone broke into the car 2 different times, i had a Infiniti Mechanic tell me the windows i used were aftermarket non OEM ones that either didnt have some sensor or since they were replaced i had to goto infiniti and have my ecm reset , i dont know if any of that makes sense but thats what i heard.
i have a g35x 2004
Old Oct 24, 2012 | 10:30 PM
sworkman31's Avatar
I have heard of resetting the limit switch on the G35. I have the same problem with my 2004. Anyone know the procedure??
Old Dec 23, 2012 | 07:54 PM
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
Does anyone know if 04 G35x's use LED bulbs for guages on the dashboard or are they regular light bulbs? Would like to also know if its a DIY project, that can be easily done.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
JMSABO
Aug 4, 2015 11:58 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
Lsantana757
Jul 20, 2015 09:08 AM
