A/C blow hot air and outside temp stuck at -22degrees,
Old Apr 24, 2010 | 05:18 AM
wannascooby's Avatar
I've been rebuilding my G since November and finally got her running for the most part. https://g35driver.com/forums/general...nd-damage.html
The whole front end up to the engine was smashed I repaired it, but I'm missing horns, front airbag speed sensor, and probably some other stuff as well.
Problem is A/C blows warm air, compressor doesn't turn on, and the outside temp gauge stays at -22 degrees.
I didn't turn the a/c on before until I tried to charge the a/c so the compressor wouldn't seize, but while recharging the compressor didn't even turn on!. I don't believe there was any leaks in the system. When I connected the a/c condensor I didn't have anything else attach to it except the two a/c lines. What should my steps be? also what do these sensors look like and where are they!
Thanks a bunch. This forum has saved me tons of money during my rebuild.
Old Apr 24, 2010 | 07:36 PM
Any ideas? Do I replace the temp sensor first or is there another reason that the outside temp isn't working>
Old Apr 25, 2010 | 01:41 AM
avs007's Avatar
Replace the sensor first... If the G's setup is like my other car, the A/C won't turn on if the outside temperature is below a certain threshold...
Old Apr 29, 2010 | 04:03 PM
Hmm..i think i see the problem. I looked 20inches below the hood latch and found nothing there!
G35Rican
Jul 31, 2024 01:37 AM
alessandro
Oct 8, 2015 09:29 AM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
