Problem with slip, vdc off, and brake lights on dash
This problem happened twice so far starting the other day. When driving, all of a sudden the emergency brake, slip, and vdc off light will be light up on the dash. If I turn the car off and back on, it goes away. Has anyone had this happen before. Any ideas on what it could be?
Thank you
Thank you
run before they come after u and scream about doin some research
https://g35driver.com/forums/v36-bra...ts-coming.html
I just replaced my pads and rotors a year ago, and they only have about 8,000 miles on them tops. But I know when I check my brake fluid will be low, so thanks for the info. I guess when I searched I used the wrong key words.
Hasanbaloch
Feb 29, 2024 08:45 PM
