which fuse is for cruise control ? ('07 G35 Coupe)
Old Jul 12, 2010 | 09:10 AM
unforgiven's Avatar
Just got an '07 G35 Coupe.
Cruise control isn't working. Info elsewhere on the 'net suggests that it might be a fuse.
The fuse diagrams on both fuse boxes do not specify a cruise fuse.
Anyone know which one it is? I kinda hate to just start yanking fuses (unless someone can tell me with certainty that it won't harm or reset stuff).
Car is still under warranty, but I'm ~100 miles away from a dealer. Just wanna check the fuse before going through the hassle of getting the car to a dealer.
Any assistance would be appreciated.
Thanks
Old Jul 12, 2010 | 01:22 PM
HotRodG35's Avatar
Most of the cruise control functions are powered thru ECM. Most likely the issue would be power to brake switch. The fuse is labeled ASC/XX (Automatic Speed Control Brake Device) something like that. It should be located in the small fuse box located front of battery. Thier are two brake switches 1 for cruise control and the other for brake lights.
Not sure if its AT or MT. Another issue might be the clutch switch.
Old Jul 12, 2010 | 01:35 PM
unforgiven's Avatar
Thanks HotRodG35!
Good info that gives me a few things to check, including the clutch switch since it's a MT.
I'll report back my findings after I get a chance to check.
Thanks again.
Old Jul 12, 2010 | 05:53 PM
unforgiven's Avatar
Dealer said to make sure brake pedal was fully up, and parking brake was fully released. Played with those, in addition to the clutch and its associated switch. Cruise is working fine now. Can't say which of those was the culprit...
Car had been on a dealer's lot for a couple of months, so perhaps the lack of use made something stick that shouldn't.
Thanks again for the help.
Hasanbaloch
Feb 29, 2024 08:45 PM
laksjd84
Jul 24, 2015 05:12 PM
CrazyLogic219
SouthEast
Jul 15, 2015 02:35 PM
beevanhuynh
Jul 14, 2015 09:06 AM
Jadenkid22
Jul 14, 2015 12:33 AM
