Driver Side Window and Lock Issue
Old Jul 18, 2010 | 01:25 PM
KapVu's Avatar
Hey everyone, got a weird problem where I'm not sure where to start.
I recently changed my battery but this problem was happening before I changed the battery too.
The issue is I can't roll down or up my windows and when that happens I'm not able to lock the doors either using the inside door automatic switch or the key fob. I am able to use the automatic window for the passenger door from the driver side and able to adjust the mirrors and all other electronics. I'm not sure if the wires to the lock and windows are bad or what's really wrong.
Also this doesn't happen all the time. Sometimes it both lock and window will work and sometimes it doesn't.
What's wrong?
Old Jul 20, 2010 | 10:08 AM
KapVu's Avatar
anyone have any ideas?
Old Jul 20, 2010 | 10:18 AM
erklep's Avatar
if youve checked all fuses, id have to say its a bad switch. doubtful that the wiring is bad
Old Nov 21, 2010 | 11:05 AM
nando023's Avatar
What's wrong?
any solution?????
Old Jul 7, 2011 | 06:39 PM
liveontheedge04's Avatar
I'm having the same problem!! My driver door lock started messing up and on hot days it would not unlock. Then today I went to roll down my window and it will not go down and the door will not lock my remote! The passenger window will work but the control on the driver door. Did you figure out what was wrong with yours??
mike730
Jan 12, 2018 04:25 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
