Clicker not working, inside locks not working.
Old Jul 18, 2010 | 05:56 PM
mellinox's Avatar
I drive an '03 auto coupe.
The clicker for the car doesn't really work like it's supposed to. If i press unlock, the lights go on like the signal hit it, but the locks don't get unlocked. Same thing happens for lock, except it makes that little honking noise. The panic button doesn't work unless i'm a foot away; actually, the range for the clicker is EXTREMELY small, i need to be 3-10 feet away for it to do anything at all. The trunk unlock works fine as long as I'm close.
Next problem: the inside switch that locks the whole car does not work. Just doesn't do anything. I have to manually reach over to the passenger side and lock it, since sticking my key in the car and locking it only locks the drivers side door.
Anyone have similar problems or know how to fix this?
Old Jul 23, 2010 | 12:41 AM
SacG35's Avatar
https://g35driver.com/forums/interio...uator-fix.html
Old Aug 8, 2010 | 06:16 PM
surma884's Avatar
As far as your remote not working, change the battery. The range should be good on it if there are no obstacles in the way. I can do it from like 100ft or so.
arora_g35
Apr 16, 2026 02:52 PM
tal1412
Nov 28, 2022 09:25 AM
mike730
Jan 12, 2018 04:25 PM
apintojr
Jul 23, 2015 10:52 AM
beevanhuynh
Jul 14, 2015 09:06 AM
