Why does my idle drop to zero after my car warms up?
Old Jul 25, 2010 | 09:27 PM
sonk55's Avatar
why does my car start fine at a cold start but wen i try to start it wen the engines warm, it shuts off unless i rev it? this all happened after my battery died wen my friend helped me change my brakes.
Old Jul 26, 2010 | 04:20 PM
tonke73's Avatar
Originally Posted by ZXERT
You may need to do the Idle Air Relearn Procedure.
My g35 was doing this and it turns out that I had carbon build-up restricting the throttlebody. Basically the throttlebody is closed at idle and any small amount of buildup totally screws up the idle. It resolves itself as your ECU learns the correct air intake. You car should not shut down after a ecu reset, ever.
So try cleaning your throttlebody. Do not, EVER EVER EVER!!!!! touch your throttlebody while its plugged in. I can guarantee you'll be buying a new one. Disconnect the battery and the connector at the throttlebody before touching it. Try to avoid moving the butterfly at all.
I've cleaned my throttlebody numerous times without unplugging it and have had zero problems.
Old Jul 26, 2010 | 04:26 PM
nghiars's Avatar
It can also be a faulty MAF sensor which is between the Airbox and the intake tube.
Old Jul 29, 2010 | 12:52 AM
tonke73's Avatar
I was wrong.
https://g35driver.com/forums/v36-diy...le-bodies.html
Read that.
Apparently IF you disconnect the wires, which you SHOULD NOT. Then DO NOT touch the butterfly valve. But its fine to touch as long as you don't disconnect the battery or TB connector. See post #4.
Good to know. I never take the TB assembly apart. I just clean it with TB spray and a rag.
Old Jul 29, 2010 | 02:05 PM
sonk55's Avatar
so i just cleaned my tb lastnight and it now starts everytime. thx a lot guys i appreciate the input
Old Aug 3, 2010 | 06:56 PM
surma884's Avatar
I disconnected the harness to the TB and moved the butterfly. No problems. I didn't have to relearn anything. I tried to do the relearn, but the instructions are so ****ing vague I gave up.
Hasanbaloch
Feb 29, 2024 08:45 PM
NemesisGee
Aug 11, 2015 07:10 PM
ghost_g35
Aug 7, 2015 10:31 AM
yassy
Aug 3, 2015 12:24 AM
Rehman2009
Jul 27, 2015 03:23 AM
