06 Projector conversion (HID won't work)
Old Aug 22, 2010 | 12:14 AM
GarGamel's Avatar
LoandSHoG35 -
i really do appreaciate all your help and tips. i'm not saying you're wrong. i'm just telling you want i did. this is my first time doing this so i'm just trying to get as much info as possible.
so my question is, beside removing your old ballast, you also remove the yellow wires too?
Old Aug 22, 2010 | 12:22 AM
LoAndShoG35's Avatar
Yes, that is what I am saying. Look at this pic that I used from another post on Driver. the long yellowish shiny wire (or wire housing) pictured (not the one circled) needs to be removed from your old headlights and run through the housing of the projectors and connected to the HID bulb and the ballast.
Old Aug 22, 2010 | 12:28 AM
GarGamel's Avatar
thanks for the pic. yes, i remove that as well.
however, on the 05 lights inside the housing where the HID bulb location, there is a 2in" yellow thin wire that has a brass color connector on each end (like how u plug speaker wires into a speaker for your car)
well, i also used that yellow wire but according to whosRich, he mentioned no need for it
would that wire cause the HID to not work?
seriously bro, i appreciate all your replys
Old Aug 22, 2010 | 03:55 PM
GarGamel's Avatar
Thank to LoandShoG35 and WhosRich for your help.
I managed to get it to work. It was the little yellow wire I mentioned about. I took it off and lights went on right away.
I guess I was right in the first place
Old Aug 27, 2010 | 04:11 PM
mjholla19's Avatar
what should i do if i want to install the 06 headlights in a 05 but i dont have the old heaadlights just buy yellow wire and wire it in
Old Jul 19, 2012 | 06:52 PM
Fantastic G's Avatar
Sorry to bump an old thread but,Thanks again to LoandShoG35 and WhosRich for your help.
You guys just helped me out too!
Seth
Jusseth
Sep 13, 2020 12:25 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
