car wont turn over
Old Sep 20, 2010 | 06:35 AM
jmoe71's Avatar
Angry car wont turn over
tryed to unlock my car with keyfob,wouldnt unlock, used key in lock, tryed to start car...nothing, battery ok, was told that its a theft deterent, if key used in door lock, it shuts down ignition...any one share my experience?...thanks in advance for any help..
Old Sep 20, 2010 | 12:01 PM
tonke73's Avatar
What? Who the heck told you that? Using your key in your door lock will not disable or shut down your ignition. I assume you have a G35 with the chip in your key? Do you have an automatic? Is the steering wheel turned to one side where it blocks you from cranking the engine? Sometimes you have to turn your steering wheel the other way to allow the key to turn to the 4 position (where it cranks the car).
Do you have any lights on the dash? You did not include enough information for anyone to help you. What year and model is your car, etc...
Old Sep 20, 2010 | 08:29 PM
lechols155's Avatar
+1 more info. is there any lights did it make any noise when you tried to start it? how do you know the battery is good
Old Sep 21, 2010 | 12:40 AM
jmoe71's Avatar
sorry guys... 03 coupe 6mt...no lights on the dash...battery tested 12.74 volts.... apparently some knucklehead!..i never heard of that, thought i had missed the boat!..thanx..i ll keep investigating..
Old Sep 21, 2010 | 09:27 AM
lechols155's Avatar
did you use a load tester on the battery or just a volt meter?
Old Sep 21, 2010 | 05:19 PM
HangUp n' Drive's Avatar
Could be batt connections/cables, I would do a quick visual and wiggle the largest wires on both ends including the ground. There is a good chance of finding somthing
Old Oct 1, 2010 | 12:45 AM
jmoe71's Avatar
Cool
thank you all for ur input....found the problem, in fact my battery WAS dead!...source was my power window motor was stuck..killed my battery.. thanx again for all the help
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
