03 sedan front passenger side window
Front passenger side window acts up when I roll the window up it goes all the way up but then comes down a quarter of the way is there a way to fix this like a button to hold down or some other quick fix? Any help is grately appreciated
found this on some site when i was having the same issue. fix my problem. (same as urs)
Retiming procedure for an Infiniti G35 and G37 Window and Moonroof
This is a common problem when retained power is lost. You will need to perform the following procedure, it’s real simple and resolves this issue. That can occur if the battery is drained and is easily reset.
1. Push the ignition switch to the ON position.
2. Close the door.
3. Open the window completely by operating the power window switch.
4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely.
5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.
6. Perform steps 2 through 5 above for other
windows.
2. Close the door.
windows.
rezendvous420
May 31, 2020 01:26 PM
Micale757
Lighting
Apr 8, 2020 10:46 AM
