Moonroof problem g35 (closes too much)
Old Oct 13, 2010 | 01:58 PM
Nomad397's Avatar
Angry Moonroof problem g35 (closes too much)
my moonroof closes too much as in when i "auto close" it slides fully foward then tilts down too much and it is not flush with the roof. i tried the timing fix and that did not work. it just pisses me off that i have to tap the tilt up 5-7 time to get it flush when i want it closed properly.
Old Oct 22, 2010 | 12:14 PM
Nomad397's Avatar
someone else has to had this problem and gotten it fixed. need help guys
Old Aug 21, 2013 | 04:03 PM
vashawn's Avatar
Bump....I just noticed this on my G coupe...sunroof when close is not fully flushed with the roof.
Anyone had this problem and fixed it....dont really open it fully just keep it on tilt...but my concern is what happens if in driving one day and hit a bump or pot hard and this **** just caves in...LOL
seriously...
Old Aug 21, 2013 | 04:06 PM
vashawn's Avatar
I will post a pic tonight
Old Sep 17, 2016 | 04:32 PM
MooseLucifer's Avatar
5 Year Member
blk
Old topic, but in my sunroof troubles I've taken mine apart a dozen times in the last few months. Every time reinstall the glass, I have to lift/lower the glass with one hand until I can feel it's flush with the roof with the other hand, then I tighten the screw to hold that corner flush.
There are 6 total bolts, 3 per side, and you have to do that with the front and rear-most bolts on all four corners of the glass to get it flush. If you remove the little plastic guards that cover the bolts, you will also see a white 'timing' mark that shows if you're aligned in the closed position. If that mark lines up, then all you need to do is adjust the glass. If that mark is not aligned, then you probably have to do the motor reset procedure.
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
wojowojo16
Jul 27, 2015 09:57 AM
laksjd84
Jul 24, 2015 05:12 PM
Soumilg
Jul 18, 2015 12:33 PM
