ticking noise
Old Oct 28, 2010 | 06:29 PM
mkvl127's Avatar
ticking noise
i just started hearing a ticking noise coming from what i think is the drivers front wheel..i no its deffinatly the front..the click speeds up as i accelerate and slows down as i break..its so quiet that i can only hear it when coasting..ive had the passanger side bearing and hub assembly replaced under warrenty about 10,000 miles ago but that was more of a humming and not a click..ive checked both front tires for rocks or nails etc.anyone have an idea..and if it is a bearing i can just replace the bearing and not the hub assembly correct?..im no longer under warrenty 2005 G35x
Old Oct 26, 2012 | 04:07 AM
bythabay's Avatar
Did you figure this out? What was it?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
