Help cant get car to start
Old Nov 1, 2010 | 06:55 PM
fatlip's Avatar
U can look up the throttle body reset procedure.
Old Nov 1, 2010 | 08:21 PM
wanabskyline's Avatar
since you have a scanner I would clear the codes and see which one comes back first. Check the ETC actuator relay since that is easy and it has a code for it (1124). Do the reset procedure and then see where you are at then. If you are still with a crank no start 1121 and 0223 point to the ETC actuator itself and I would have the dealer take a look at it to be sure before you go spending that kind of money without being sure.
If you can, have someone look at the throttle plate KOEO (key on engine off) and press the throttle a few times to be sure the throttle plate is moving
Old Nov 1, 2010 | 09:41 PM
the_sedan's Avatar
replace the etc. then perform APP learn (KOn3KOff10), then IAVL (KOn3KOff10 3 times), then you should be good to go........
Old Dec 11, 2010 | 01:43 AM
Flipjnh's Avatar
What codes came back?
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
