IPDM Fan Radiator relays Location??
Old Nov 1, 2010 | 10:59 AM
Sac2904's Avatar
Hi everyone,
My radiator fans wont stop either engine hot or cold. I think I need to check the relay which is behind the battery, within the IPDM box. I opened it but then I couldn't tell which one is radiator relays.....could someone please point out for me, I really appreciate it.
Attached Thumbnails IPDM Fan Radiator relays Location??-g35-2004-coupe-relays-panel.jpg
Old Nov 3, 2010 | 11:00 AM
HangUp n' Drive's Avatar
The fan relays are the three large ones in the middle of your photo. The middle relay is #1, the left hand relay is #2, the right hand relay is #3. If you AC is on the fans will run. The fan high/low/off conditions are explained in the serivce maunal page ec-525. The fan relay wiring is page ec-530. The IPDM E/R outline and terminal drawing is page pg-25.
These page numbers are from the 06 coupe manual, Im not sure what model yours is but it looks the same.
Old Nov 3, 2010 | 11:44 AM
Sac2904's Avatar
Sweet, thank so much!!! that was I need for this weekend project..
Old Dec 11, 2010 | 01:40 AM
Flipjnh's Avatar
Check relay #2 because that is just a redundant Ground relay, 1 and 3 are from your WT sensor to kick the fan on and your AC. Are your fans running on high or idle low?
Old Dec 14, 2010 | 01:44 PM
Sac2904's Avatar
these fans are running high.. someone told me just find some relays from the 350Z and replace them instead of buying a whole kit.
Old Sep 14, 2012 | 10:47 PM
yoyo221's Avatar
which one is the tail lamp relay!help!
Old May 22, 2023 | 10:15 PM
jk319's Avatar
Infiniti G35 Sedan Automatic no mods
SAC2904,
I have the same problem: fans won't shut off after they've been turned on. What was the fix for your problem? I see that this is an old post...
KevinnnVo
Oct 14, 2024 04:33 PM
ZoominG35
Dec 6, 2015 03:11 PM
pasjr1972
Sep 1, 2015 10:17 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
