Car wont start when turning key.
Old Feb 14, 2011 | 09:25 PM
Draven83's Avatar
Hey everyone, Well i am watching my friends 04 G35 Coupe while he is on leave. And there have been a few times when i turn the key that it wont do anything. Yes i press the clutch, i have tried putting it in gear and also neutral and still wont do anything. Has anyone had this problem? What do you think it might be?
Chris
Old Feb 15, 2011 | 09:45 AM
mojo9's Avatar
Is it turning over but not firing?...if so, is the anti-theft light on solid while it is cranking? If that's the case, the ignition is not recognizing the chip in the key & may need reprogrammed, it happened to me. It was an intermittent problem
Old Mar 31, 2011 | 09:45 PM
strykez's Avatar
check the floor mats. maybe your not depressing the clutch pedal all the way down do to winter floor mats.
Old Apr 1, 2011 | 05:58 PM
longcoo817's Avatar
maybe the battery is dead?
Old Apr 2, 2011 | 02:33 PM
Bassman's Avatar
If nothing is happening, not cranking , maybe the starter is shot.
Old Apr 2, 2011 | 03:03 PM
dofu's Avatar
20 Year Member
If your battery is dead, you can hear the battery clicking from it trying to pull power. If it cranks and turns but won't start, it could be your alternator. Otherwise, it's your starter. If you have over 60k on the odo, it most likely is your starter.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
kenthung
Jul 21, 2015 05:56 AM
