Water sound from dash
Old Feb 19, 2011 | 10:41 PM
jacksonG35's Avatar
OK guys don't flame me too bad for this one.
Ive had my 04 G35 Sport for about 3 weeks now. Love the car and everything about it. Got one question though...
I hear a "sloshing water sound" from behind the dash over the steering wheel when I back out and put it into Drive.
This only happens when I first get in the car and put it in reverse,no other time of the day.
Any ideas on what this could be or where its coming from??
Thanks in advance for any help here.
Old Feb 20, 2011 | 12:43 AM
bigc's Avatar
Wings Nation
do you get hot air from the A/C when you turn the heat all the way up?
Old Feb 20, 2011 | 12:44 AM
G35SedanGrn's Avatar
could possibly be your abs self test, i guess you could describe the sound as water sloshing around.
Old Feb 20, 2011 | 03:27 AM
sTeadFasT96's Avatar
More than likely you have an air bubble in your coolant line. Try having the car running with the heater on and open the coolant relief valve and let the bubbles come out until it stops. That should fix the problem.
Old Feb 25, 2011 | 06:30 PM
NJ 666's Avatar
Is the coolant jug full? When the car is cold remove the radiator cap and see if the little pressure relief button is stuck. I've seen these stick and allow coolant into the jug but not return and the system get air in it.
Old Feb 27, 2011 | 09:58 PM
ldg870's Avatar
It could be the brake booster vacuum. It's right behind the driver's side dash in the engine compartment. Mine makes noise every morning right out of my driveway.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
1Typhoon
Sep 25, 2015 08:45 PM
Albanian122
Sep 12, 2015 04:02 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
