Help check engine light on P1706 PNP switch-no signal change
Old Feb 20, 2011 | 12:43 PM
westbank23's Avatar
Question Help check engine light on P1706 PNP switch-no signal change
My cel light came on this morning and I brought it to autozone and it pulled up
Trouble shooting p1706
OEM brand:Infiniti
Definition
Probable cause
Open or short circuit condition
Poor electrical connection
Faulty PNP switch
Anyone know what this means?
My car runs and drives good and the only noticeable problems I have are the map lights don't work(maybe blown fuse or blown lights)driver side reverse light blown and front driver turn signal bulb blown.
It's a 04 6speed
Old Feb 25, 2011 | 06:26 PM
NJ 666's Avatar
6 speed doesn't have a PNP switch. I'll check ASIST and see what it is for a 6 speed
Old Feb 26, 2011 | 12:23 AM
westbank23's Avatar
Yea I googled PNP switch and it dose seem like its just for automatics that's been confuseing me so I brought it to 3other autozones and it keeps giving me the sane codes
Old Feb 26, 2011 | 12:32 AM
westbank23's Avatar
What do you mean by ASIST?
Old Feb 27, 2011 | 10:10 PM
35dprace's Avatar
my check engine light came on today after i cleaned my fuel sending units. How do you re-set it ?
Old Mar 2, 2011 | 10:49 AM
NJ 666's Avatar
This code is an indication that the neutral position switch is not sending a signal to the ECM. It is a very simple circuit and should be easily diagnosed. Has the transmission been out recently? Perhaps it was left unplugged.
Since there is no control unit for 6 speeds this is the code that the ECM sets.
Old Mar 2, 2011 | 11:37 AM
westbank23's Avatar
Thanks nj666
I don't know if the transmission been replaced or pulled out because I just brought the car with 72xxx miles on it.would I be able to find the switch if I get under the car and look around the tranny area?
Old Mar 3, 2011 | 11:54 AM
NJ 666's Avatar
The Neutral position switch is located on the right(passenger) side of the transmission. It is above and just forward of the transmission mount. There is also a switch on the left side that is for the reverse lamps. Make sure they are both plugged in.
ASIST is the information source/data base that we use at Infiniti/Nissan.
Old Mar 3, 2011 | 07:26 PM
westbank23's Avatar
Ok thanks I'll check it out later.well it be easier to locate the switch if I crawl under the car or will I be able to see it under the hood?
Also if you don't mine can you take a look at my other thread concerning what the Infiniti dealership told me about M/T fluid
https://g35driver.com/forums/g-spot/...-gear-oil.html
Old Mar 4, 2011 | 08:51 AM
NJ 666's Avatar
Have to get to it from under the car. Best on a lift. I think there is a sticky on here for the service manual, it should show the location.
Old Mar 4, 2011 | 09:55 AM
westbank23's Avatar
Ok I'll check it out in a few days when I get off work
Old Nov 20, 2015 | 10:44 PM
nitish21's Avatar
Did you ever figure it out?
Hey I have the same issue did yo ever end up figuring it out? I recently put a new transmission in and I have had the engine light since and I just unplugged and re plugged in that sensor and I still have a engine light. Do I have to do a battery reset or something?
Old Jul 19, 2021 | 12:49 AM
Aggyvq's Avatar
G35 rev up coupeeeee 2005
This is a super old thread but wondering if anyone ever figured out the issue I have a 05 rev up manual coupe - same code P1706 …
my car is tuned and I use the coast/set and cancel button to change between maps when it’s set the set light on the dash flashes the number of times per map example if I want map 3 I hold down coast/set while pushing cancel 3 times and when let go the set light on the dash flashes 3 times - sometimes the set light flashes - sometimes it doesn’t. Not sure what could be causing that issue, but mostly confused about the P1706 code.
thankssss
Old Jul 19, 2021 | 10:51 AM
telcoman's Avatar
Veteran: Army
thankssss
Have you consulted the FSM?
https://www.nicoclub.com/service-man...F2005%2Fec.pdf
See page EC-582
DTC P1706 PNP SWITCH
Edition: 2004 September 2005 G35 Coupe
DTC P1706 PNP SWITCH PFP:32006
Component Description ABS00E1S
When the shift lever position is P or N (A/T), Neutral (M/T), park/neutral position (PNP) switch is ON.
ECM detects the position because the continuity of the line (the ON signal) exists.
Then the TCM sends the PNP switch signal to the ECM via combination meter. (A/T models)
CONSULT-II Reference Value in Data Monitor Mode
DTC No. Trouble diagnosis name DTC detecting condition Possible cause
P1706
1706
Park/neutral position
switch
The signal of the park/neutral position (PNP)
switch is not changed in the process of engine
starting and driving.
 Harness or connectors
[The park/neutral position (PNP) switch
circuit is open or shorted.]
 Park/neutral position (PNP) switch
 TCM (A/T models)
 Combination meter (A/T models)
Use your multimeter and let us know how you make out
Good luck
Old Jul 19, 2021 | 04:00 PM
LoSt180's Avatar
thankssss
#1 - changing maps has nothing to do with check engine light codes
#2 - Code is pretty simple: the car isn't detecting a change in the neutral position switch even though the car is being driven. It's a simple circuit, starting with a switch on the side of the trans: make sure it's still plugged in and not damaged. Basically if the ECU thinks the car is in neutral, it won't activate the CAM phasers (int & exh) and the car will generally feel kinda slow.
