M/T & Diff Oil Change...which oil?!?
Old Mar 12, 2011 | 11:32 PM
maclovio's Avatar
So my car is coming up on 60K miles soon. I want to change the oil on the M/T and the differential myself. Just want to make sure that both use Nissan HQ Multi 75W-85 oil.... Also, how many quarts does each take? I already changed the brake pads and 2 drive belts. I will also change the incabin air filter. Anything else i should check?
Old Mar 13, 2011 | 03:32 PM
sillyoldtayo's Avatar
https://g35driver.com/forums/engine-...id-change.html
Good thread to check out. I believe the answer to your question is in the first post. Other things to change on your car are brake/power steering fluids and the battery.
Old Mar 13, 2011 | 03:51 PM
maclovio's Avatar
Thanks bro.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
