AWD Tie Rod End?
Old Apr 13, 2011 | 11:09 PM
Cardinal's Avatar
AWD Tie Rod End?
I have searched and came up empty. Can anybody advise if there is an aftermarket tie rod inner and outer for the 04 X? I have inquired with vendors from megan racing and spl performance but they can't advise if it will work on the x. Has anybody used other than oem?
Old Aug 2, 2011 | 08:50 AM
mikedamageinc's Avatar
I picked up a Moog inner tie rod from Advance Auto recently since I bent one..dont ask! It is much beefier than the stock piece, not sure if it is necessary but it sounds like that is what you are looking for. I havent actually replaced it yet, time and reading thru the write up has me putting it off. Here's the link: https://g35driver.com/forums/brakes-...placement.html
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Jeff T
Sep 30, 2015 02:00 PM
