Issue with sterring
Old Jun 12, 2011 | 09:47 PM
imaxorz's Avatar
Issue with steering
I was driving around on some twisty roads around where I live and when going around a tight right turn there was a really loud bang sound that came from my left wheel area. It sounded like when you tighten a bolt until it breaks.
So, I drove home to check it out. While driving home the car was responsive at always, and it does not feel like there is a problem. However I did noticed it made a weird sound when moving the steering wheel side to side fast, so I took my tire to investigate.
This is what I found. You can hear the noise in the video. This is with the wheel off the car, when the wheel is on it, it sounds completely different, and not as loud. I assume because then there is weight on the parts.
The view you see is of me laying under the car. The shiny part with grease on it, is usually under a boot that I took off. Again this is on the driver side of the car.
Any idea what it is? I don't want to buy parts before knowing that it is for sure.
Thank you!
Old Jun 19, 2011 | 12:56 PM
imaxorz's Avatar
Anyone?
Old Jun 19, 2011 | 01:20 PM
chink-ah-saur's Avatar
did your alignment get f"d after this?
Old Jun 21, 2011 | 08:41 AM
imaxorz's Avatar
Nope, the alignment is perfectly fine, and the car still drives/handles fine.
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
