Window Problem (Not motor or controller) helpz.
Old Jun 13, 2011 | 09:57 PM
nimjox's Avatar
My problem is that I started experiencing problems with my windows not going down/up (both at same time. I didn't think it was the motors because the driver window/lock controller makes a clicking/hissing sound (like a bad relay, especially when it’s hot, i.e. in GA now all the time). Despite that, after reading how the motors are always going out I replaced the motor, no luck, still random working/not working condition. So I go to the dealer and get the window controller and replace it, but even the replacement still makes the hiss/clicking sound. Luckily I was able to return the motors and controller but I have no clue what could be causing the problem. It really sounds like a power issue with the relays in the controller but I have no clue what’s regulating it, what the voltage should be, also maybe a grounding issue. Any thoughts or ideas would be sooooo much appreciated. Thanks in advance.
Classification: UNCLASSIFIED
Old Jun 13, 2011 | 10:48 PM
DHCrocks's Avatar
I had that problem I got clicking noises, I switched out the motors no go. bought a new switch no go. I finally figured out that it was the connection where the door meets the body of the car. There is a lever that you pull out to unlock the harness, you get to it be reaching between the door and the frame, it's a tight fit and you need small hands. try releasing the lever and jiggling the connector then setting the lock back in. that did the trick for me and never gave me problems again. Must have just been a bad connection.
Old Jun 14, 2011 | 09:25 AM
nimjox's Avatar
Thank you so much<3, can't wait to give it a try after work.
leo38cheng
Nov 12, 2015 06:49 PM
leo38cheng
Interior
Aug 18, 2015 06:30 AM
ev_g35
Interior
Aug 14, 2015 02:05 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
