E fan wiring 03 Sedan
I recently got a Mishimoto fan shroud kit and the radiator along with Hayden thermostatic fan switch. After reading few threads here I could understand the basic wiring tip from Eric@TCGMiami's post.
Red (Power, you get this from the battery)
Black (Ground, you can get it from the battery or from a nearby ground)
Yellow (Ignition On signal.. So the fans kick on when the car is on, or you can connect it to the red cable and have it on whenever the temperature reaches its target even with the car off this is how I have it)
Orange (Positive for fan #1)
Blue (Positive for fan #2)
The problem is that where do I hook up the green wire? I want the fan to stay on when the A/C is on, and remove the auxillary efan and install transmission cooler on that spot instead. where is the easiest accessible location for the A/C switch wire? I have no idea how to do the wiring for this green wire so if anyone can help I would appreciate it. Thanks.
This is the info I was looking for. Thanks for your help. I can finally locate the wire!
nettcar
Aug 25, 2024 11:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
