Please help! No brake pedal after swap!
Old Sep 23, 2011 | 09:06 PM
adam_G35Sedan's Avatar
So I changed over to the dual piston calipers, pads and rotors from a 2005 to my 2003 Infiniti G35 Sedan with the 6MT. After I bled the brakes several times, THE PEDAL STILL WENT RIGHT TO THE FLOOR! I have been bleeding the air out of these for 3 days now and still no pedal! If you pump the pedal repeatedly it firms up, then you let off, wait a second or two, then you press the pedal again and it goes right to the floor! My car does have VDC, and ABS so maybe that's why its not working? Worth mentioning for someone who really knows these cars!
I manually bled, vacuum bled, and I even got my buddy to pump the calipers all the way out and then I bled them while I pushed them back in!
I also bench bled the master cylinder, bled the ABS module, and bled the brakes all around again and it still does the same thing!
So I pinched off the brake lines with special clamps and the brake pedal stayed firm. Then i released one side and the pedal still dropped, then the other and the pedal dropped.
No leaks as I checked several times!
I cant see it being my booster cause before I did the swap, everything worked great!
I put the original brakes back on and bled the whole system again and the brakes work fine!
No idea whats going on!
Can anyone help???!!!
Old Sep 23, 2011 | 09:25 PM
Glex25's Avatar
Administrator
Brake booster
I had to do that for a brembo swap (2003 G35 brembo to a 2007 350z) I did for someone
Old Sep 23, 2011 | 09:29 PM
Swap out the brake booster from the 2005 model and put it into my 2003?
Old Sep 23, 2011 | 09:34 PM
Glex25's Avatar
Administrator
^ Yes
I would swap the master cylinder and brake booster
Old Sep 23, 2011 | 09:37 PM
So I double checked the part numbers and they are not the same for the booster from the 2003 to the 2005?
I am just wondering if these mount up the same?
Old Sep 23, 2011 | 09:49 PM
underthesun1020's Avatar
Also check that you put the rear calipers on the right side, if you didn't then the bleeder screw will be on the bottom instead of the top. Only know this because it happened to me and a friend.
Old Sep 23, 2011 | 09:57 PM
I have only done the swap over of the front! Do you think I should swap over the rears?
Old Sep 23, 2011 | 10:00 PM
No, the fronts only fit on one side or the other, the rears will fit on either side technically. That wouldn't/shouldn't have anything to do with it. Not sure what to tell you to try next.
Old Sep 24, 2011 | 06:33 AM
So this whole thing just doesn't make sense!
I just realized that I didn't check to make sure the calipers were on the right side! Maybe they were on the wrong side and that would put the bleeder screw at the bottom of the caliper so that would not allow me to bleed them out!
I'm gonna remount them and make sure they are on the right side, I will let u guys know when I'm done!
Thanks for all your help guys! Nice to see a forum that helps out the average gear head!
Old Sep 24, 2011 | 03:37 PM
So don't laugh to hard but I went and made sure I put the right caliper on the right side and bang, it works great!
I guess u over look a lot of stuff when ur in a hurry!
Old Sep 24, 2011 | 05:34 PM
Glad that worked, I know how frustrated we were for 2 days!!
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Joe Gargano
Sep 18, 2015 11:17 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
