06 RWD ABS sensor on 04 AWD?
Old Oct 2, 2011 | 10:09 PM
G35xTurbo's Avatar
So, I have been looking around for a used replacement driver's front ABS sensor for my 04 X for a while now and they are over $200 new and tough to find used. I found a driver's front ABS sensor on e-bay from an 06 RWD sedan and contacted the seller. They said that it should fit for an AWD 04. They had it listed as fitting 03-06 so I took a chance because it was a good deal. I received it today and installed it and at first all related lights (AWD, VDC OFF, SLIP, and ABS) lights went off. I backed the car out of the garage and took it for a spin and it almost immediately kicked on the VDC OFF and SLIP lights. I started to turn around because it was acting a little strange (hesitant) but before I could even do that, maybe 100 feet from my drive way, all 4 lights came back on and the car drove normally. My question is, shouldn't the sensors be pretty much the same? If it will fit in the 04 harness (it was just plug and play pretty much) shouldn't it work fine? I would like my AWD back by winter, haha. Thanks for any tips you can give me.
Old Oct 3, 2011 | 08:21 AM
vigman's Avatar
Well not knowing I would call the dealer and see if the part # are the same.
That would be a place to start?
Mike
Old Oct 3, 2011 | 09:11 PM
G35xTurbo's Avatar
Yeah, that's what I'm gonna do. Just wondered if anybody had any experience on this. Thanks though!
Old Oct 4, 2011 | 11:05 AM
Infiniti Parts Online's Avatar
According to Infiniti's catalog lookup, the 2WD and AWD ABS sensors for the front are different. They may look the same, but there's alway s that slight difference ( more likely internallty ) that make it different from one to another.
The part number for the AWD is 47910-AL805 and that is the same for both sides on the front.
Old Oct 5, 2011 | 12:51 PM
G35xTurbo's Avatar
Awesome! Thanks for the help. Anyone need a new one for the front of their RWD sedan?
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
