In need of some dimensions on the radiator
So I have an aftermarket radiator that was " customized ".
The brackets on the front of the bottom tank that hold the A/C condenser were cut off.
Since this is a BIG radiator ( 56mm ) I would really like to use it for the L/A heat.
So what I'm looking for is a picture with dimensions of the lower tank brackets
eg how big the cutout is for the lower condenser mounting points & how far the slot starts from the lower tank...
I've already made the brackets but I would like to cut the openings out BEFORE welding them back on to the tank..
Thanks
Mike
Thanks
Mike
BradMD_96
Oct 6, 2015 09:31 AM
lavtxa
Sep 21, 2015 11:51 AM
