Car Will Not Start Up...Please Help
Old Nov 13, 2011 | 02:19 PM
blackhat5's Avatar
Hi guys. I have a 2005 G35 Coupe A/T and when I woke up this morning, my car would start, but the following lights displayed on the dash:
VDC OFF
ABS
SLIP
When I tried to push on the brake pedal and switch it into drive, the shifter **** is completely locked.
I read on here to check the fuses for the rear brake lights, and low and behold, the fuse was blown. So, I replace it, and now the brake lights are fine, but the car won't start at all now.
I checked the engine bay fuses, all seem fine. I also disconnected both battery cables to reset the computer, and that did not help either.
When I switch the key to the ON position, I hear two "knocking" sounds in the engine, which I was told is normal.
I guess I am confused as so why the car started this morning, and then once changing the fuse out, it will not start at all now.
Any help would grealty be appreciated, as now I cannot get my daily driver to start at all.
Thanks a million!
Old Nov 13, 2011 | 02:56 PM
blackhat5's Avatar
Just an update, we tried jump starting the car and it will not start or turnover either.
Texasscout's Avatar
will it start if you pull the fuse back out?
Old Nov 13, 2011 | 03:02 PM
blackhat5's Avatar
No.
Now, the owner's manual showed the fuses in the engine bay, and we took out one box fuse that held fuses for the vdc, abs, etc. and when we put that back in, is when the car wouldn't start. Sorry I might have explained the process incorrectly.
Old Nov 13, 2011 | 03:09 PM
blackhat5's Avatar
Also when I turn the car to the ON position, the lights inside light up, but when i try to start it, all the lights go off until I switch it back to the ON position.
Old Nov 13, 2011 | 04:14 PM
Texasscout's Avatar
That's normal, all power is directed to the starter when it is energized.
You must have something out of whack with the computer. See if you can borrow an OBD2 reader and check for a code. That would be a good starting place.
Old Nov 13, 2011 | 05:52 PM
blackhat5's Avatar
Ok thanks I'll try that.
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
