brake lights fuse burned!
Old Nov 16, 2011 | 08:10 PM
satmar's Avatar
Hello guys, let's see if anyone of you have had this problem before, my 10 amps. fuse belonginging to the brake lights went off and that made me unable to shift the lever from park, I discovered the problem and simply replaced the fuse for spare in the box, running good for 6 days and today again the fuse blowed up, aha I replaced it again but this time blowed just when I applied the brake to see the tail lights on and no able to move the shiftlever from park due to lack of electrical power, so I did a bridge with a thin electrical wire only to see if I was able to shift from park to any other speed and... worked! but still no brake lights...I believe something's wrong with the LED brake lights but not sure where, so, please help guiding me to solve my problem, I don't want to get caught in the hands of the stealership, anyway those "mechanics" only knows change tires, batteries and charging high fees. Again thanks:
Old Nov 17, 2011 | 09:47 AM
Eno's Avatar
Eno
A guy with a thread beneath you is having the same issue. Might want to blend these threads. I wish I could helP but it's a head scratcher.
mike730
Jan 12, 2018 04:25 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
Lsantana757
Jul 20, 2015 09:08 AM
