how to tighten belts
hi. I'm getting a loud squeal from the belts in the morning. from what I've read here it seems the belts need tightening. can this be done from the top or do I have to lift the car. thnx
Before anything else, make sure you visually inspect the belts. I had the same problem in the mornings/cold/rain and ended up that one of my belts was falling apart!
you need to remove the lower splash guard and tighten the pulley that tensions the serpentine belt. don't let it squeal too long or else you permanently glaze the belt and it will forever squeal till you put a new one on.
yeah I ended up replacing them so i wouldn't have to mess w it again for a while. very easy DIY. the old belts were after market and not in bad shape at all in fact they looked new. this is why OEM is best when it comes to belts. thnx for reply guys
fyi no theyre not rebadged the old belt was a goodyear and it was completely different design. oem was more felty inner lining but the goodyear had bumpy tread design. also, goodyear said made in mexico and oem japan.
what i meant was nissan doesn't make belts. another company makes it for them, so it can be manufactured by good year, gates, dayco, etc etc, but branded nissan. the felt lined belts are quieter for sure, the v notch was supppose to last longer then the traditional unlined rubber belts. i personally like the felt lined belts more too.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
