0301 code
Old Jan 22, 2012 | 07:53 AM
Gossmerjr2's Avatar
0301 code
i was wondering if some could help? I have 07 G35X. I replace spark plugs because mis fire in cylinder number 1 and was getting 0301 code. After i replace plugs still had problem. I switched coil packs and still have the same problem in number one cylinder and my 0301 code.I also took coil pack with old plug and grounded it out while runing the car and if was firing. The car has 79 thousand miles on it. Any ideas?
Old Oct 26, 2012 | 04:03 AM
bythabay's Avatar
Perhaps there is a problem with the fuel injector for that cylinder? Did you happen to check that?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
