Horn works intermittently: 2007 G35 Coupe 6mt
Old Mar 3, 2012 | 11:03 AM
fusQer's Avatar
Question Horn works intermittently: 2007 G35 Coupe 6mt
My horn works intermittently only. Sometimes it works, sometimes it doesn't. I can't seem to find any circumstances or coincidences (such as engine hot or cold, weather hot or cold, day or night, etc.) where it makes a difference. I've turned the car on and off mid-driving to see if a reboot helps, but it doesn't.
Since it does sometimes work, it doesn't appear to be a fuse issue.
Everything is stock except I have an aftermarket Viper alarm that was installed when the car was new back in 2007 (have had no problems since).
Any idea what I should check for? It is very dangerous to drive without a horn! Thanks!
Old Oct 26, 2012 | 03:55 AM
bythabay's Avatar
Next time your horn doesn't work, try rotating the steering wheel around to see if it helps. At the same time, try pressing your radio buttons on the steering wheel - they usually share the same wiring harness so they shouldn't work either, although I am not certain of that with respect to the G platform.
If you confirm that turning the steering wheel resolves the horn noise, then you probably need a new clock spring.
arora_g35
Apr 16, 2026 02:52 PM
R350k5
Oct 1, 2015 08:41 PM
nervseele
Jul 17, 2015 11:21 PM
driftsucky
Jul 15, 2015 12:38 PM
