Having keyless entry issuess, need assistance
Old Mar 25, 2012 | 10:48 AM
infinity031's Avatar
Hey guys, so if you remember posted a while ago about my keyless problems and they are still there, however had it narrowed down to the reciever, and just wondering if I found the right box, going to attach a picture to see if I am on the right track, thanks.
Attached Thumbnails Having keyless entry issuess, need assistance-keyless.jpg
Old Mar 26, 2012 | 05:23 AM
05_SkylineSedan's Avatar
20 Year Member
Here's where the boxes are located in '05/'06. (Keyless unit, and I-key unit). Good luck.
Attached Thumbnails Having keyless entry issuess, need assistance-keyless.jpg   Having keyless entry issuess, need assistance-ikey.jpg
Old Mar 26, 2012 | 07:13 AM
Thanks for the reply, I went off a that photo from the manual to remove it from my car, just wondering if indeed that is the keyless unit, and does anyone know where to order one? Dealers charge way too much! Please help haha.
Old Mar 26, 2012 | 05:40 PM
20 Year Member
Well, if pulling that only affected the keyless entry system then you probably got the right box.
And one last time - all the fuses and "links" below are involved in this system as well as several ground points (this is '05/'06).
But if everything points to this box then it certainly could be the culprit. Looks like a replacement is around $275 new from parts dealers. Maybe you can find one from a salvage yard or somebody parting out a car? Or, maybe you could bust your box open and see if you can spot any bad solder joints or anything obvious. That's a long shot but if you're gonna to toss it anyway what have you got to lose?
Hope you can get it working.
Attached Thumbnails Having keyless entry issuess, need assistance-entry-fuses.jpg
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
stratous01
Oct 7, 2015 10:19 AM
dcsbh1
Oct 1, 2015 03:15 PM
