Key FOB battery replacement
Old Apr 16, 2012 | 10:33 AM
DocD's Avatar
I own a 06 G35 and I'm pretty sure the battery is down on the fob. I have read on here that all you have to do is stick a knife in between the 2 halves and it will pop open. Ummmm I can see me screwing that up pretty quickly.
Does anyone have any pictures of how to pull this off w/o screwing up or scratching the key fob?
Thanks.
Old Apr 16, 2012 | 10:41 AM
DocD's Avatar
Here's a pic of the fob so someone can say hey stick a knife in that whole and you won't screw up your fob - hehe.
Old Apr 16, 2012 | 10:51 AM
herrschaft's Avatar
Just pry it open from the back, it easily comes apart.
Old Apr 16, 2012 | 11:00 AM
DocD's Avatar
Thanks for the reply. I must be too squeamish to really "pry" on it. I was just hoping there was some trick I was missing. Ha.
Old Apr 16, 2012 | 05:39 PM
saywat?'s Avatar
idk about urs but for the 03 style fobs the manual (the one that comes with the car) tells u how to open it which was with a coin in between the opens. looks at ur manual maybe it tell you how to open it there.
Old Apr 16, 2012 | 05:52 PM
DocD's Avatar
Thanks again for the replies. I did finally get it by simply sticking fingernails (mine - ha) in between the grooves and just prying it open. It does indeed pry open but not quite as easily or as simply as I would have thought. The battery was a CR2025 for anyone else with an 06 G35.
chinee
Jun 10, 2024 07:48 PM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
JMSABO
Aug 4, 2015 11:58 AM
apintojr
Jul 23, 2015 10:52 AM
