Idle air volume reset question
Old Nov 1, 2012 | 10:33 PM
einstein**-7's Avatar
Just wondering if anyone knows if the reset procedure for the reseting the Idle air volume is correct. After holding the excellerator for 20 seconds and releasing it says 'start engine' never says to turn the Ignition OFF. Procedure works as described but the car dosn't seem to run any different. Once i did turn the ignition off before starting and car ran rough for about 10-15 seconds -- makes me wonder if the procedure didn't forget something.
Old Jan 16, 2013 | 02:02 PM
bythabay's Avatar
sometimes the relearn won't work, even if you do it correctly - then you have to have a scan tool to start the relearn while the car is already running.
champppy
Mar 31, 2020 12:25 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Gip
Aug 24, 2015 05:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
