car not starting after motor build
Old Dec 15, 2012 | 10:16 PM
Th3R3dStar323's Avatar
I had a similar issue but I have a 6mt and the clutch needed to be lined up properly with the crankshaft positioning sensor. I don't think you would have this issue since you are 5at..
Old Dec 15, 2012 | 11:53 PM
lucid215's Avatar
yea a real good mechanic is helping me and he's starting to get stumped
Posted from G35driver.com App for Android
Old Dec 18, 2012 | 08:13 PM
lucid215's Avatar
so still not starting. I have fuel and spark. redid the timing. some how I had got water in the tank and I had to drain it all out and put fresh gas in. did a compression test and only got 30 psi on cylinder one. I didn't do a check on any others. I'm completely stumped and on my last leg.
Old Jan 7, 2013 | 04:54 PM
lucid215's Avatar
still not running and still no solutions
Old Jan 7, 2013 | 05:04 PM
broke_as_ajoke's Avatar
wow.. I wish u the best bro.. Did u come up with any other ideas? Who installed the motor and were all the piece put back and doubled checked?
Old Jan 7, 2013 | 05:19 PM
lucid215's Avatar
havent came up with anything. everything i have thought of i tried and failed. the only thing i didnt do is assemble the short block. everything else i did myself. i doubled and tripled checked everything. gonna have to take it in to someone whos a z/g specialist.
Old Jan 7, 2013 | 05:21 PM
6mtg's Avatar
Had a similar problem on a Honda few years back and it was a ground wire that went from the fuse panel to the motor just double check all the grounds, connections, make sure all the plugs are in the right place, you can pull a coil and ground it with a set of jumper cables where the screw goes to hold the coil down and put a plug in it, have a friend turn the car over and see if you have spark
Old Jan 7, 2013 | 05:31 PM
lucid215's Avatar
yea i got spark
Old Jan 7, 2013 | 05:34 PM
6mtg's Avatar
What about the volts in your battery? If the battery is low or weak it Won't start sometimes has something to due with the computer
Old Jan 7, 2013 | 05:35 PM
6mtg's Avatar
Is the crank sensor plugged in? Did you try to shoot some starting fluid in the intake while trying to start it
Old Jan 7, 2013 | 05:54 PM
lucid215's Avatar
battery is brand new. even put it on a jumper box. sensor is plugged in and even tried it without the sensor plugged in. yes even tried starter fluid.
Old Jan 7, 2013 | 06:07 PM
6mtg's Avatar
Well as much as I hate to say it sounds like timing, even tho you said you already checked it but that's all you have left lol
Old Jan 7, 2013 | 06:22 PM
lucid215's Avatar
I have redone the timing twice and even went by the fsm
Old Jan 7, 2013 | 06:58 PM
6mtg's Avatar
Turn ignition switch off
Turn ignition switch on but do not start wait 5 seconds then turn back off
Do 3 cycles of this then try to start
Try this
Old Jan 7, 2013 | 07:00 PM
  #30
lucid215's Avatar
done that to hahaha
