P Shift Error and crazy sound
Old Dec 15, 2012 | 03:20 PM
Soorma718's Avatar
Ever since last week every day now when i get out of the car and lock it a crazy dog wistle type of sound goes off. it is constant. And behind the steering wheel it says "P Shift". I figured out it has something to do with my shift handle. It is not going in full park. I had to start the car and push it up (into park) really hard and then the sound and the message went away. Anyone know how much it would cost to fix this? I'm guessing its a big problem
Old Dec 16, 2012 | 01:27 PM
05_SkylineSedan's Avatar
20 Year Member
The sound is the external alarm warning you that it's not in Park. You don't want it to roll down the hill! There are a bunch of possible causes, everything from a linkage problem to a cable mount to an electrical switch to even motor mounts (??). Important to fix but probably not a major thing. Best bet to figure it out would probably be the dealer..
Old Aug 2, 2021 | 03:09 PM
Z107G35s's Avatar
G35s sedan twin turbo greddy, high-low cats, tien coil overs ,greddy exhaust, mst 19.5 inch rims,
They way to fix the car is to disconnect the yellow fuse that goes to your obd 2 sensor. I did this and the problem is solved.
Old Aug 30, 2022 | 03:59 PM
10x's Avatar
10x
infiniti g35xs sedan
P shift error
hey Z107G35s. I have the same problem. do u know where the fuse is located and the exact one that needs to be disconnected.
cam3L5rider
Drivetrain
Oct 4, 2011 06:01 PM
XternaL
Aug 18, 2011 05:15 PM
M-azing.
Drivetrain
Feb 25, 2011 09:23 PM
vash_g35
Mar 4, 2008 11:38 AM
Psycraft
Dec 13, 2006 07:40 AM
