clutch sticks to the floor... help!
2003 g35 coupe 76k miles
temp is in the mid 30's
all of a sudden my clutch just started sticking to the floor, i can pull it back up but theres not a chance of driving it. I checked quickly to see my brake fluid level and its fine. my guess is either air in the lines or a bad slave cylinder, or possibly a bad throwout bearing? let me know what you guys think from experience. i havent checked to see if there are any leaks my car is currently getting towed
3 things typically. Fluid, Slave and then Master in that order. Last things are the Clutch line, pivot ball or clutch/flywheel.
The slave should run you typically $30-$50. Run some fresh dot 4 through the lines and bleed it accordingly. Bleeding is a pain in the as* on this car and have patience young padawan.
Hogbone
Sep 28, 2015 06:44 PM
jbmw002
Sep 10, 2015 12:54 AM
