oem trans cooler bypass possible.
Old Dec 31, 2012 | 12:30 PM
hallman's Avatar
2003 g35 coupe 5AT. I just replace the radiator the car is running great, but after driving it for half an hour I noticed my trans cooler hoses had come off. Would it be safe to bypass the transmission cooler?
Old Dec 31, 2012 | 12:41 PM
HotRodG35's Avatar
Not unless you want to overheat transmission.
Transmission cooler lines should be easy to re-attach, My concern would be replacing the transmission fluid.
Old Dec 31, 2012 | 12:49 PM
bigc's Avatar
Wings Nation
+1 re-attach those lines and check your AT fluid level using the procedure in the service manual. Throw some worm gear clamps on the lines if you're worried about them popping off again.
Old Dec 31, 2012 | 12:54 PM
hallman's Avatar
I believe I will replace the lines and put worm gear clamps on. I'm seriously not looking forward to adding more fluid to the trans. 03 G ftl.
Old Dec 31, 2012 | 01:11 PM
herrschaft's Avatar
Adding a little fluid should be the least of your concern
Old Dec 31, 2012 | 01:32 PM
hallman's Avatar
Considering I have to climb under the car to add it I agree with you. Its the least of my concerns but none the less it sucks. Speaking of, anyone know the size of the Allen head bolt? I can't remember.
EPG35
Aug 16, 2015 04:52 PM
NemesisGee
Aug 11, 2015 07:10 PM
saskicker32
Aug 11, 2015 02:12 PM
newg37
Jul 26, 2015 09:32 AM
