is this normal?
Old Jun 5, 2013 | 04:32 AM
DieuNay's Avatar
is this normal?
is this normal for a g35 to idle this low?
*iphone pic*
Old Jun 5, 2013 | 04:43 AM
SxExCx's Avatar
Its fine as long as it doesnt stall
Old Jun 5, 2013 | 04:55 AM
DieuNay's Avatar
alright, thanks.
Old Jun 5, 2013 | 10:43 AM
jookyshank's Avatar
I haz hugz to givez
Prius mode?
If Sean says it's good...it's good!
Old Jun 28, 2013 | 03:18 PM
ErikTaylor's Avatar
Damn I was worried at 400. I'd freak if it was at 100. As said as long as it doesn't stall you're good!
Old Jul 24, 2013 | 01:52 PM
hdmark's Avatar
im sitting about 600 also. not sure if you were still worried about it or anything. but it seems everytime i install a new mod somewhere in the intake/exhaust area it lowers just slightly
Old Jul 24, 2013 | 10:12 PM
saywat?'s Avatar
fkers need to learn how to properly read the rpm gauge
Old Jul 24, 2013 | 11:00 PM
bluedevils95's Avatar
Well, at least you be saving money at a red light being that low
Old Jul 24, 2013 | 11:27 PM
gary c's Avatar
Normal idle when your G is totally warmed up is 400 rpms, I'd do a "Idle Reset!" (Search) At 100 rpm I'd be concerned about oil pressure being to low....Gary
Old Jul 25, 2013 | 03:41 AM
scottvt's Avatar
I may be dumb, but that looks like 600RPMs to me.
Old Jul 25, 2013 | 08:30 AM
Mustang5L5's Avatar
It's 600RPM in that pic
Personal experience....factory tachometers are not always accurate
Old Jul 25, 2013 | 02:51 PM
saywat?'s Avatar
are u serious dude?
Old Jul 25, 2013 | 08:51 PM
Your right. 600 is still prety low though.
Old Jul 26, 2013 | 01:31 PM
munroejj's Avatar
Mine Idles just as low
My 2003 G35 6MT, idles at 600 rpm when first started and after about 10-15 seconds its at 150-200rpms......I've followed the DIY steps to reset the ECU, Accelerator Pedal Release position Learning Operation, Throttle valve closed position learning, Idle Air volume learning TP learning......I have done them correctly as I had the CEL come on and do what it was supposed to, and it cleared up after....In the process of doing the IDEL air volume learning it stalled my car out when I tried to start it...I then started it again and it seems okay... but still revving way too low....Any thoughts? Just installed a new Takeda Air intake with a new filter....Will try cleaning the throttle body....
Old Jul 29, 2013 | 11:21 AM
munroejj's Avatar
Cleaned the throttle body.....Still revving too low....Any ideas?
