wiring auto/homelink rear-view mirror.
Old Jun 17, 2013 | 01:44 PM
TheIronYuppy's Avatar
My sedan's manual mirror was loose, and I just picked up an OEM automatic mirror from a wrecked 05 sedan. Of course my car doesn't have the correct harness for a powered rearview mirror, but...
I had already sourced a constant 12v + lead from the maplight circuit, and I use it to power my radar detector.
Which wire from the mirror is the one to use for the automatic dimmer? Which one is the ground?
I don't care about the homelink features, just the dimmer.
Thanks in advance.
Old Jun 18, 2013 | 05:35 PM
05_SkylineSedan's Avatar
20 Year Member
Here you go... Pin 8 on the mirror's plug should be ground (black), pin-5 should be constant voltage (black/red), and pin-6 is voltage when running (black/pink). If you don't want the garage door opener you can probably ignore pin-5 and just power pin-6 and ground.
File Type: pdf
Old Jun 18, 2013 | 08:09 PM
Great, thanks!
Busy weekend coming up for the car: double din deck, new wheels and tires, and now the mirror upgrade.
I really need to buy that shop manual.....
Old Jun 18, 2013 | 10:47 PM
herrschaft's Avatar
Thats from the factory service manual, which can be found here: https://g35driver.com/forums/faq-diy...e-manuals.html
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
