Help: Exhaust Valve Timing Control Position Sensors
I got the Check Engine Light, The Code number I got was P1084. I am trying to look for the part instead of buying from the dealer but I cannot find it. Is there a specific site I can buy it from or is the sensor called something else?
2006 Infiniti G35 6MT coupe.
any nissan parts place online will carry it. IIRC 1084 was for the passenger side. the camshaft sensors you have to place differ by bank. one is angled slightly one isnt. wherever you buy it from make sure its OEM from nissan. going with a non oem one will usually lead to them going bad and lead to another headache.
The sensor part number is 23731-AL61A for passenger side exhaust valve timing sensor. This is also the same part number for driver side intake cam sensor. The sensor part number for driver side exhaust valve timing is 23731-6J90B.This is also the same part number for the passenger side intake cam position sensor
Thaaa_king
Jul 18, 2015 05:56 PM
