Help! Car starts but won't stay on
Old Mar 13, 2014 | 03:12 PM
aprilmaejun's Avatar
Hey guys..
So the other day, I replaced the AC outlet fuse in my car because it was blown out. Stupidly, I decided to check up on the other fuses both by the clutch and under the hood. After that whenever I try to start my car, it'll turn on for a second then just die right away. However, if I press on the gas after it starts (even a tiny bit just to jump the rpm a little) it will stay on.
I checked and made sure that the other fuses weren't blown and that they were in the right place. It drives perfectly after I press the gas a little at start but it idles at a really low RPM around 500.. and when it is idling it feels like its almost going to shut off again, but it doesn't.
Does anyone know a solution? Do I just have to do a throttle and ECU reset or something of that nature? Any help would be very much appreciated. Thanks guys.
Also, idk if this helps, but when I turned on my car afer I changed the fuse the outside temp meter was erratic and it started at 100 and worked its way down to the actual temp. The odometer trips also were reset.
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
realtalk21
Jul 20, 2015 09:07 AM
Thaaa_king
Jul 18, 2015 05:56 PM
