I got P2A00 code, advice please
Old Mar 20, 2014 | 04:05 PM
hipi2002's Avatar
I was driving south with the family to Miami when after filling up and continuing down the highway, the SES light came on. Went to one of the big chain stores to see what the code referred to and it is P2A00. The O2 sensor. So I know that I'm probably going to have to see if there's a leak and/or see if the O2 sensor(s) failed. I do have mods, ART PIPES, stillen headers, XYZ pipe, and an Osiris tune. Any advice from those who hold reputable mechanical knowledge of the G35?
Old Mar 20, 2014 | 08:27 PM
seymore4's Avatar
m56
You pretty much nailed it on the head. One of those two
Old Mar 20, 2014 | 10:21 PM
Urbanengineer's Avatar
If you are involved with tuning yourself, you should look into an upgraded aftermarket o2 sensor for more accurate readings.
Old Mar 20, 2014 | 10:23 PM
seymore4's Avatar
m56
Please elaborate
Old Mar 20, 2014 | 10:46 PM
Originally Posted by seymore4
Please elaborate
I went to the local tuner today... Guess I should've just asked you first -.-
Old Mar 20, 2014 | 11:08 PM
seymore4's Avatar
m56
As long as you're not in an 03 the factory widebands are more than sufficient for tuning. Built motor/ high HP builds of course are different..
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Fox843
Nov 7, 2015 05:43 PM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
