Need help confirming a spacer
Old May 1, 2014 | 03:46 PM
PLENUMCOUPE's Avatar
Hrey guys I bought my car with a plenum spacer already on it and I just want to identify which one it is or if it's even one at all because I haven't actually seen clear pictures of one on another car. I think it's the MD 5/16" but I'm hoping someone can confirm. Also if there's any noticeable things that can be pointed out to know if it's the Iso-thermal or not.
Attached Thumbnails Need help confirming a spacer-image-1306970520.jpg   Need help confirming a spacer-image-2818556421.jpg
Old May 1, 2014 | 03:53 PM
Jeff92se's Avatar
Red Card Crew
To confirm which one, just measure the thickness. The only flat non-Moterdyone space is the 3/8" thick copy. I don't remember what makes it iso-thermal but that might be a gasket inbetween the lower plenum and the intake manifold attached to the heads. Will be almost impossible to see if that's there.
Old May 1, 2014 | 05:43 PM
U see the pics? Is the metal piece just under the upper plenum the spacer or is that stock?
Old May 1, 2014 | 06:00 PM
Jeff92se's Avatar
Red Card Crew
Right pic has a spacer. WHICH spacer, 5/16", 3/8" or the 1/4" can't be determined w/o measuring it. but yes, there is a spacer in there.
Old May 1, 2014 | 06:10 PM
Urbanengineer's Avatar
You have a plenum spacer yes. You can't be certain without measuring it with a simple ruler. Blox and Skunk2 also make spacers. I think blox are 3/8 like Jeff says and skunk is 5/8 (too big) (citation needed).
Your name is plenum coupe. You should know this
Old May 1, 2014 | 06:19 PM
Jeff92se's Avatar
Red Card Crew
Old May 1, 2014 | 07:34 PM
Shawno72's Avatar
On my screen I measure 5/16 md spacer. Only way to tell if it's ISO thermal is to look below the lower plenum and see if you can see a thicker than stock gasket, if it can be seen at all I believe the blox and skunk2 are made from that plastic material but I could be wrong
Old May 1, 2014 | 07:35 PM
Yeah... No. It's internal.
Old May 1, 2014 | 07:44 PM
gary c's Avatar
Does the engine cover fit? If so it a 5/16" spacer, if not it's probably 1/2" like mine or 3/8". If it's copper can only be proved by removing upper and lower plenum and manifold! Is it worth the trouble to find out?
Gary
Old May 1, 2014 | 07:53 PM
Shawno72's Avatar
If you do remove to find out, you may as well have a new aramid gasket just in case.
Old May 1, 2014 | 08:11 PM
SxExCx's Avatar
That is a Motordyne 5/16" spacer. You can look under your intake tube to see if there is a coolant control valve which would confirm that it is the isothermal kit
Old May 1, 2014 | 08:13 PM
Shawno72's Avatar
As long as they installed the ccv
Old May 1, 2014 | 08:34 PM
I knew some would say this haha at least it's not plenumspacercoupe
Originally Posted by gary c
Does the engine cover fit? If so it a 5/16" spacer, if not it's probably 1/2" like mine or 3/8". If it's copper can only be proved by removing upper and lower plenum and manifold! Is it worth the trouble to find out? Gary
The engine cover did fit b4 I took it off so it must must be 5/16.
what does it look like?
Old May 1, 2014 | 08:57 PM
SxExCx's Avatar
google "motordyne coolant control valve" to see what it looks like and where to find it on the motor.
Old May 1, 2014 | 09:17 PM
Will do. Thanks guys
