should I only use a Nissan radiator cap?
Old May 8, 2014 | 12:14 AM
ScraggleRock's Avatar
Dude, i had some coolant under my car today. Opened the hood, heard a hiss, pressed down on the radiator cap and it stopped. Bad cap, right? Went to O'Reilly and got whatever brand they carry, put it on and now same shib. Still hissing. I changed to a screw clamp on the upper radiator hose (that's where it was leaking) so its not leaking anymore, but still got steam and hissing from the cap. Is that one of those parts that I should keep OEM?
Old May 8, 2014 | 12:46 AM
coffeysm's Avatar
Might sound stupid, but are you sure it's latching correctly on the neck of the radiator? Have done that myself a few times...
Old May 8, 2014 | 01:03 AM
Yeah, I'm sure, but it had very little spring resistance when I put it on.
What do you mean tho? Just so I can eliminate that as a cause. Is there more than one way to put it on?
Old May 8, 2014 | 02:48 AM
maclovio's Avatar
I had this problem after my radiator was changed and the shop put aftermarket cap instead of OEM nissan cap. Problem was solved after OEM cap was purchased and installed.
Old May 8, 2014 | 07:16 AM
Cool. Gonna grab one today *crosses fingers*
Old May 8, 2014 | 05:25 PM
Holy, ****, man. Worst day ever. Overheated on the way to work, had to call out. Pressure tested the car and the radiator is cracked. Just pulled the radiator (kind of a b!tch) now waiting for CarQuest to call about the new one they got me. And on top of that, my hazards killed my battery. Tested it and it was fried. Had to get a new one of those too. Jesus..
Old May 8, 2014 | 07:11 PM
Urbanengineer's Avatar
Yikes! It's the little things sometimes. Good to know you weren't injured or anything when it did fail.
Old May 8, 2014 | 09:35 PM
Shanes_G's Avatar
Well now you know it wasent the cap.
Old May 9, 2014 | 12:10 AM
coffeysm's Avatar
That sucks. I bought an eBay radiator for 60 bucks 6 months and still going strong.
Old May 10, 2014 | 09:34 PM
maclovio's Avatar
+1
cross that one out!
Old May 10, 2014 | 09:45 PM
Haha, I ended up having to change the thermostat too. That was a bad day. It sucked cuz I just got a chemical flush. Probably what messed everything up.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
BradMD_96
Oct 6, 2015 09:31 AM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
